Joshbseen
Jul 04, 2022Aspirant
Factory reset C3000, have internet but can't access router wifi network
So I did a factory reset on an C3000 N300 wifi cable modem router combo. We have 3 computers connected; 2 via wifi and 1 via ethernet. All 3 can launch browsers and access various web sites....
Jul 05, 2022Guru - Experienced User
Try going to 192.168.100.1
Also, make sure IPv6 is enabled.
Try a different DNS Server. Here's a few for ipv4. Also remember to change the ipv6 dns server if ipv6 is enabled
CloudFlare 1.1.1.1 and 1.0.0.1
GoogleDNS 8.8.8.8 and 8.8.4.4
Joshbseen
Jul 05, 2022Aspirant
Hey thanks for responding.
That IP address sent the same message of "not connected to router's wifi network." This is on an ethernet connection.
I tried with both a Google and Cloudflare dns on the pc end.
Is this an ISP issue? I have factory reset before and never, to my memory, had this issue before. I run through Comcast, so just the thought of contacting customer service depresses me.
- plemansJul 06, 2022Guru - Experienced User
Try factory resetting 1 more time. But disconnect the coax cable from the modem. Then push and hold reset for 7-15 seconds while powered on.
Then try and connect and follow the install guide.
Try using a windows pc if you're on mac/ios
- JoshbseenJul 06, 2022Aspirant
Yeah I did all that.
I even contacted the ISP. They did a reset on their end and confirmed the modem/router had no issue from their side.
Established the modem/router has gone into critical failure mode.
Purchased a Nighthawk AC1900 wifi cable modem router and am currently enjoying quite an improvement to internet speeds and functions all around.
Thank you for responding. I posted everywhere and you where pretty much the only one that chimed in.
