BruceBeam
Nov 20, 2016Follower
Factory reset N300 WIFI Cable Modem Router and now cannot access internet via browser
IMy Internet provider issues me a static IP address, when I changed to this router, I forgot to enter that. Tried today only to find the original numbers they gave me had changed so it would not let...
DarrenM
Nov 23, 2016Sr. NETGEAR Moderator
Hello BruceBeam
You will want to open a command prompt on your PC by going to your run bar and typing CMD hit enter then in the black box type ipconfig hit enter then find the ip address beside default gateway then use that Ip to get into your router.
DarrenM
- michaelkenwardNov 23, 2016Guru - Experienced User
If you happen to be one of those "bleeding edge" users of Windows 10, you may have lost the Command Prompt. (Microsoft is removing it in favour of Powershell, which you can also use to run IPConfig.)
Another way to get where you want is through Open network in Explorer, then look at the Network infrastructure bit, right click and then View device web page.
