necuja
Nov 09, 2016Aspirant
factory reset not working
so i forgot my router login password so i decided to factory reset it and did exactly like instructions say i held the button for 7 seconds and sometimes even longer (tried reseting 3 times) and ever...
necuja
Yes it did and I even unplugged did every solution I could find.. I have access to internet so not sure what my isp can do for me it's the fact I want to update my firmware but can't unless I can log into the router
Retired_Member
Nov 09, 2016You're welcome,
Is there a new firmware to update the c3700 to, I couldn't find one. What makes you think there is one.
I believe if firmware is updated it's done by the ISP.
Call them and have them reset the Password for you.
