lokilo
Sep 17, 2022Aspirant
Factory reset on a cable modem to deal w/intermittent internet
My Internet has been spotty for the past several days. The first time it happened, internet came back on after unplugging the coax cable and plugging it back in. It worked! And I cancelled the spectru...
michaelkenward
Sep 17, 2022Guru - Experienced User
Can you tell us a bit more about what happens? Do the LEDs show any clues? Does in the Internet disconnect? Is it just wifi that goes down? Do wired devices stay on?
That just interrupts the cable signal to the Internet. A reboot (power on/off) is more normal.
Trying to figure out if my issue is with the coax cable or with the cable modem router itself.
If you have another cable, try it. A faulty cable is far from unknown.
I have the C3700, running the latest firmware. What happens if I select “factory reset” on the admin page?
The firmware is beyond your control. Only the ISP can change that.
The factory reset, the same as pressing the reset button on the back, simply takes the device back to its "out of the box" state. This is a standard troubleshooting move and is worth trying if you have persistent problems.
As this is a cable modem/router, plemans, who understands this stuff, might be able to step in with advice on how to check the quality of your Internet service.
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Cable Modems & Routers
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
lokilo
Thanks so much for your reply.
When my Internet disconnects, off the top of my head, I can’t remember if the smart lights go out. But yeah, all other devices lose Internet.
After posting my question, I managed to find the Netgear customer support number. The tech-support person told me that the cable modem itself is in perfect condition.
I went out and bought another coaxial cable, installed it, and called my ISP. They are detecting anomalies, So I scheduled another ISP tech visit. For next Saturday!! Had I not canceled the original one, my issue would be hopefully getting resolved right now!
