MA-CLE's avatar
MA-CLE
Failing to connect to Pro1 thermostat from Nighthawk C7000
I cannot get my Pro1 thermostat to connect to WiFi. The requirementfor the thermostat are: Use ports 1883, 8883(MQTT), and 443(TLS Default) The Pro1 WIFI thermostats support commissioning via WPA2 wi...
