pchadrow
Aug 11, 2021Aspirant
Failing to connect to router or connect multiple devices at once
My ISP is CAS cable. I've been running firmware V3.02.01. For some time there's been some odd behavior with establishing multiple connections to the modem but overall has been working okay as I've ha...
- Aug 12, 2021
Be sure to swap out LAN cables. CAT6 is recommended.
Power OFF both modem and router for 30 seconds, then power ON the modem then router. Check status on the router. If it still fails, you'll need to conect the mfr of this router for help and support redarding there product.
pchadrow wrote:
Well that explains the multiple device problem I guess. I'm still unsure as to why I can't seem to get it to recognize a connection with the router. With only the router being connected, no LAN ports show any LED activity. The router gives an error that a network cable is unplugged. I've tried using all four of the lan ports on the modem hoping one of the ports may be faulty but none of them register a connection to the router. Any other wired connection to a laptop or desktop is fine, just the router. Is there anything else to try I'm not thinking of or is this more likely a port issue on the router?
Aug 11, 2021Guru - Experienced User
What is the mfr and model of the router connected to the modem?
Be sure LAG is disabled on the modem.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
pchadrow
Router is a TP-Link AX6000. Signal wise, all is well. If a single device is plugged into the modem it works fine (aside from my router) but trying to connect both my desktop and laptop via ethernet and only one seems to get assigned a valid IP while the other is stuck on "unidentified network"
Also, connection wise it can't get much better. It's connected via a brand new RG6 line that's about 200 ft going directly into the ISPs line from the pole. I've already power cycled it numerous times and various ways and have completely disconnected everything and let it sit for 5 minutes before reconnecting. No changes.
- FURRYe38Aug 11, 2021Guru - Experienced User
Are you trying to connect other wired devices to the modem? If so, you can't do this. Only 1 device can be connected to the modem and thats your wifi router. The other ports are for other routers however that needs services from yoru ISP which most ISPs only service 1 port, port#1. You would have to ask your ISP if using the other ports is supported or not. You have to connect your other wifi devices to the wifi router for internet services. If there having problems at this point, you'll need to contact the mfr of this router for help and information regarding there product.
- pchadrowAug 11, 2021Aspirant
- antinodeAug 11, 2021Guru
> [...] I'm still unsure as to why I can't seem to get it to recognize a
> connection with the router. [...]Too many pronouns. I'm still unsure as to what "it" means, or what
"recognize" means to you. Which part of "actual" was unclear to you?> [...] The router gives an error that a network cable is unplugged.
> [...]If a computer works when it's connected directly to the modem, and
the router does not, then I'd worry about the router, not about the
modem. Especially if the router complains about a connection to a
known-good modem port through a known-good cable.For a quick port test on the router, connect each end of a
known-good cable to a LAN Ethernet port on the router, and observe the
relevant port-status LED indicators. For a good cable, both port-status
LEDs should indicate a maximum-speed connection. (And they should
agree.)
You could also run a known-good cable from a LAN port to the
WAN/Internet port, and look at the _LAN_ port-status LED. (Because the
"Internet" indicator works differently.) That would test the
WAN/Internet port.Or, at least, that's what I'd expect from Netgear router.
