sanchep2
Jan 24, 2017Aspirant
FAST LAN speed / slow WiFi speed
I have register my cable modem with xfinity and i do have internet access when i connect to the 5g Wifi I get at most 54Mbps but when connected via ethernet to the netgear box i get the 75+ Mbps ...
DarrenM
Jan 27, 2017Sr. NETGEAR Moderator
Hello sancep2
Have you tried to change the wireless channel Also I have seen if you change the modem to a lower speed it can fix some wifi speed issues.
DarrenM
sanchep2
Jan 30, 2017Aspirant
on 2.4 GHZ i have tested 3 6 and 11
and on 5Ghz i have used the empty one
i am starting to think that the box is busted
still no luck
