mirage8101
Jun 16, 2016Follower
Fast LAN speed/slow WiFi speeds Netgear C3000
I am getting good speed with LAN cable with my Netgear C3000, but speed is half when I am using wifi. I checked Firmware version. Its upto date. Can some one let me know how to improve perfor...
Jonoregon
Sep 07, 2016Tutor
mirage8101 wrote:I am getting good speed with LAN cable with my Netgear C3000, but speed is half when I am using wifi.
Can some one let me know how to improve performance/speed when using wifi.
I'm having the same issue. 80 wired 14 wireless
- DarrenMSep 09, 2016Sr. NETGEAR Moderator
Have you guys tried to change the wireless channel to see if you get a better wifi signal? other networks in the area or home appliances can affect the wifi signal.
DarrenM
- JonoregonSep 09, 2016Tutor
Channel 3 got me up to 25 Mbps.
This is with the wireless device about 5 feet from the C3000
I called into support and they had me change a few setting and nothing changed the performance. Then they told me to call comcast and get them to downgrade the firmware. Comcast says "they don't do that"
