mirage8101
Jun 16, 2016Follower
Fast LAN speed/slow WiFi speeds Netgear C3000
I am getting good speed with LAN cable with my Netgear C3000, but speed is half when I am using wifi. I checked Firmware version. Its upto date. Can some one let me know how to improve perfor...
DarrenM
Sep 09, 2016Sr. NETGEAR Moderator
Have you guys tried to change the wireless channel to see if you get a better wifi signal? other networks in the area or home appliances can affect the wifi signal.
DarrenM
Jonoregon
Sep 09, 2016Tutor
Channel 3 got me up to 25 Mbps.
This is with the wireless device about 5 feet from the C3000
I called into support and they had me change a few setting and nothing changed the performance. Then they told me to call comcast and get them to downgrade the firmware. Comcast says "they don't do that"
