tony123456
May 13, 2020Aspirant
FCM1100 : Frequent disconnect from internet with Optimum using Netgear CM1100 modem.
I am facing issues of frequent disconnects. From last 2 months I was facing lower speeds, 30Mbps or less on a plan of 300Mbps but upload spped is intact. I contacted Optimum and they told to contact ...
- May 13, 2020
Have the ISP check the signal and line quality UP to the modem.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
tony123456
May 15, 2020Aspirant
its not happening anymore. I had and old splitter and used it instead of directly connection modem to wall.
May 16, 2020Guru - Experienced User
Enjoy. :smileywink:
