azdeltawye
Jul 06, 2024Aspirant
Feature request: Add spectrum analyzer to CM3000 modem
Hello, I recently purchased a Netgear CM3000 modem to replace a Motorola MB8600. The CM3000 seems like a solid modem, no complaints so far. However, I definitely miss the spectrum analyzer for advanc...
azdeltawye
Jul 07, 2024Aspirant
Hmmm strange.
What firmware are you running in the CM3000?
What is your ISP?
If I try to access port 8080 on the modem, the connection just times out.
Nothing in the user manual about a spectrum analyzer...
Thx,
Jul 07, 2024Guru - Experienced User
V4.01.01
Sparklight
- azdeltawyeJul 07, 2024Aspirant
OK, that must be it then. I'm on Comcast/Xfinity and running firmware version: 5.01.02. What puzzles me is that my old Motorola MB8600 had a working spectrum analyzer, same ISP...
To access the spectrum analyzer, do you have to use port 8080 or is there a separate tab in the UI?
Thx again!
- FURRYe38Jul 07, 2024Guru - Experienced User
8080 worked for me. Possible that ISP maybe limiting. I remember my CM2000 had same feature thru the port.
