Vpbomp
Sep 21, 2020Aspirant
Firmware file c7000
Hello !!I am looking for a firmware file for this device, mine bricked itself ;( during an update lost power
Sep 21, 2020Guru - Experienced User
That's not good.
there isn't a firmeware file because it comes from the isp.
You can attempt to have the isp re-provision it or reinstall firmware but its not something the user can do.
- VpbompSep 21, 2020Aspirant
I'm able to communicate with the unit
Same ip schem, subnet.
I believe I can send the file over tftp
Just need the file
- plemansSep 21, 2020Guru - Experienced User
Again, you can't get the file. Only the isp has it. its the way combo devices work and one of the reason's we usually recommend people buy modems seperate from routers.
Have you tried a factory reset?
Or a 30/30/30 reset?
- VpbompSep 21, 2020AspirantYeah,
Tried the little Netgear application too
Called Cox they won't give the file.
Should have had a ups
Or modem/router
