Vpbomp
Sep 21, 2020Aspirant
Firmware file c7000
Hello !!I am looking for a firmware file for this device, mine bricked itself ;( during an update lost power
Vpbomp
I'm able to communicate with the unit
Same ip schem, subnet.
I believe I can send the file over tftp
Just need the file
Sep 21, 2020Guru - Experienced User
Again, you can't get the file. Only the isp has it. its the way combo devices work and one of the reason's we usually recommend people buy modems seperate from routers.
Have you tried a factory reset?
Or a 30/30/30 reset?
- VpbompSep 21, 2020AspirantYeah,
Tried the little Netgear application too
Called Cox they won't give the file.
Should have had a ups
Or modem/router
