Tom10036
Oct 01, 2020Guide
Firmware update c7000v2
My internet is not working. Spectrum told me that I need to update my WiFi router. I installed nighthawk app from iPhone and I’m stuck at the step where it shows firmware out-of-date. From my laptop c...
- Oct 01, 2020
So its not getting any signal.
go to where the coax enters the home and directly connect tthe coax to the modem. This ensures nothing in the home is causing an issue.
Tom10036
Oct 03, 2020Guide
Cable technician was able to fix it. As you indicated, it wasn’t a problem with netgear. Thanks a bunch!
ByronT
Oct 19, 2020Initiate
What did the tech do to resolve the problem?
I’m having the same issue except I can connect to the internet
- Tom10036Oct 19, 2020GuideThey fixed the problem from Spectrum system. It was fixed after the tech made multiple phone calls to Spectrum over 2 hours. My router didn’t have a problem but Spectrum did something from their end to fix this problem.
- ByronTOct 19, 2020InitiateThank You
I have spectrum also and I’m calling for service! Thanks- OragnzOct 31, 2020Initiate
My ISP (RCN) is telling me they don't push out firmware updates to customer owned equipment. How can I update my firmware if you don't support a method for an individual to perform the operation? My firmware is V1.02.04. The latest I see in the list for my hardware is V1.03.01 (Comcast). The oldest I see under the "other ISP" category is V1.02.14. That's still seriously behind. Being that far behind on firmware could seriously make me vulnerable. Netgear should not let the ISP have control over this function.
