Tom10036
Oct 01, 2020Guide
Firmware update c7000v2
My internet is not working. Spectrum told me that I need to update my WiFi router. I installed nighthawk app from iPhone and I’m stuck at the step where it shows firmware out-of-date. From my laptop c...
- Oct 01, 2020
So its not getting any signal.
go to where the coax enters the home and directly connect tthe coax to the modem. This ensures nothing in the home is causing an issue.
ByronT
Oct 19, 2020Initiate
Thank You
I have spectrum also and I’m calling for service! Thanks
Oragnz
Oct 31, 2020Initiate
My ISP (RCN) is telling me they don't push out firmware updates to customer owned equipment. How can I update my firmware if you don't support a method for an individual to perform the operation? My firmware is V1.02.04. The latest I see in the list for my hardware is V1.03.01 (Comcast). The oldest I see under the "other ISP" category is V1.02.14. That's still seriously behind. Being that far behind on firmware could seriously make me vulnerable. Netgear should not let the ISP have control over this function.
- plemansNov 02, 2020Guru - Experienced User
Netgear should not let the ISP have control over this function.Its not something netgear has control of. Its part of the docsis 3.0/3.1 spec. And its not only Netgear has this issue.
And they DID do something about it. The newst CAX80 was made powerful enough they could seperate out the modem/router firmware so the router portion is updatable. But not the modem side. That's all controlled by the isp.
If you want control over it, buy a modem seperate from the router and not an integrated unit.
- OragnzNov 18, 2020Initiate
That's a rich solution. And I do mean rich... $400+ for the router and another $100+ for the modem. I was just looking for a generic firmware solution and possibly a company that stands behind its products. Bye Bye Netgear
- FURRYe38Nov 18, 2020Guru - Experienced User
Good Luck.
