CSchveder74
Apr 28, 2018Aspirant
Firmware update for CM400
I received an email a few weeks ago saying that there is an important security firmware update that needs to be installed, but when I follow the directions to download and install it, I'm told that i...
moocowcow
Jul 14, 2018Initiate
I hope this helps other people reading this thread. After spending 3 hours going back and forth between Netgear and Comcast, I learned that Comcast will do a firmware push if you just request a modem reset. Apparently, a modem reset will automatically push the latest firmware version to your modem. If you explicitly ask for a firmware push, the agent may not be knowledgeable enough to know that they can accomplish this through a modem reset as opposed to something more explicit on their end. That's when they will tell you it cannot be done.
- BredusaDec 10, 2018AspirantHas the rest to update the firmware been confirmed? I am about to return the c7000v2 I just vought because I spoke with a Comcast tech support person today and they did not even know what firmware was. Once I explained it in laymans terms they contacted a higher level and the response was....get ready.... Comcast does not update firmware for privatley owned routers!
