sparky0721's avatar
sparky0721
Firmware Update for CM500
Hi,
I need to update my firmware for my CM500 modem.  Per Netgear, it should be V1.01.05 but mine is still V1.01.04 (according to modem when I log in from home network).  Because Netgear says I need to call my ISP to update, I tried calling Spectrum who said they couldn't do it (but they are sending someone out on Sunday to see if it can be figured out).
What other options do I have?
Thanks.
  • What problem are you experiencing that you think new firmware will fix?
    Spectrum won't update your modem, so there is no alternative way to update it.
    • sparky0721's avatar
      sparky0721
      On my PC, I can't connect to the internet and connection to network is spotty at best, and my android's Genie app says "no internet connection" even after connecting to network. However, my iPad DOES connect to the network AND internet.
      The firmware update was just a guess re: what the problem actually is.
      • djc6's avatar
        djc6
        Luminary
        If one device has solid connectivity and another does not, then the problem isn't with your modem.  Since ALL of your internet traffic passes in/out of the modem, it will impact all devices equally.
        Just to make sure its not your modem, when you log into your modem administrative web page, what do your signal levels look like?  How many correctable/uncorrectable errors, etc?  Its probably best to take a screenshot of this information and post it.
        What router do you have?  Is it somehwat centrally located inside your home?  Does it have latest firmware?
