jmcoppola
Aug 15, 2020Guide
Firmware update not possible with Nighthawk or RouterLogin
I have been on the phone for HOURS with both NETGEAR and my ISP (RCN) with the issue that the firmware on.m my device can’t be updated by either party: Netgear says that they cannot update it, that it is the ISP’s responsibility, and RCN says it is the manufacturer’s responsibility. As much as Netgear claims that one can use the Noghthawk App to do this, that info is also false and should be removed on the Netgear support site AND the Nighthawk app. All the app does is detect that the firmware is out of date and can connect you to Router Login, but that’s it. There is NOWHERE on RouterLogin to update the firmware. You can reboot the device or reset to factory settings. My device is an RMA device sent to me directly from Netgear with out of date firmware. Yet NO ONE can help me update it. Not Netgear and not RCN. I called around to another ISP (Comcast) who *claims* they will support the firmware upgrade, but I can’t be sure they aren’t using that as a bait and switch tactic to get my business. Please, someone, give me some
answers here....!! Thanks!
User applied Firmware updates are not supported on any kind of cable ISP modem. ISPs control FW updates on cable modems.
- I think I was a bit unclear. The modem is mine (I own it. Not the ISP). Which is why the ISPs are saying they won’t automatically update the firmware. But Netgear does not have an end user solution to update it on your own...which totally sucks. Unless someone here has a solution..?!?
Let me be a bit more clear, for user owned modems, there is no user applied updates. ISP control FW updates for user owned modems. Some ISPs will update FW, some will not. It's all up to the ISP.
