JustMakeItWork2
Jun 01, 2022Initiate
firmware update V10.01.07
I have a CM1000V2, upgraded to firmware V10.01.07 via my IPS. Now I can't access the modem GUI via wifi on any browser, any device. Was directed to use Ethernet between PC and modem. This worked, but...
Jun 01, 2022Guru - Experienced User
Try 192.168.100.1?
What is the brand and model of the host wifi router connected to the modem?
Try a factory reset and setup from scratch. Press the reset button for 10 seconds then release.
If this still happens, contact that ISP about this.
Who is your ISP?
- JustMakeItWork2Jun 02, 2022Initiate
orbits rbr50. 192.168.100.1 does not work. time out via browser. using terminal, i get one valid ping response, then endless Request timeout for icmp_seq. reset to factory settings, still not connecting via wifi. was there a change in v10 that would have caused this?
- FURRYe38Jun 02, 2022Guru - Experienced User
Take the RBR50 out of the mix and just connect 1 wired PC to the modem.
Who is your ISP?
