JustMakeItWork2
Jun 01, 2022Initiate
firmware update V10.01.07
I have a CM1000V2, upgraded to firmware V10.01.07 via my IPS. Now I can't access the modem GUI via wifi on any browser, any device. Was directed to use Ethernet between PC and modem. This worked, but...
JustMakeItWork2
Jun 02, 2022Initiate
orbits rbr50. 192.168.100.1 does not work. time out via browser. using terminal, i get one valid ping response, then endless Request timeout for icmp_seq. reset to factory settings, still not connecting via wifi. was there a change in v10 that would have caused this?
Jun 02, 2022Guru - Experienced User
Take the RBR50 out of the mix and just connect 1 wired PC to the modem.
Try a factory reset and setup from scratch. Press the reset button for 10 seconds then release.
If this still happens, contact that ISP about this.
Who is your ISP?
