JustMakeItWork2
Jun 01, 2022Initiate
firmware update V10.01.07
I have a CM1000V2, upgraded to firmware V10.01.07 via my IPS. Now I can't access the modem GUI via wifi on any browser, any device. Was directed to use Ethernet between PC and modem. This worked, but...
Jun 02, 2022Guru - Experienced User
Take the RBR50 out of the mix and just connect 1 wired PC to the modem.
Try a factory reset and setup from scratch. Press the reset button for 10 seconds then release.
If this still happens, contact that ISP about this.
Who is your ISP?
