corvairbob
Jan 19, 2018Tutor
firmware update
how do i do this the lik fails to work Security Updates Available WHY YOU ARE RECEIVING THIS EMAIL: NETGEAR values the security of your network and data so we have released new firmwa...
corvairbob
Jan 19, 2018Tutor
i figure it was a hoax because i did what they said and my router doen't have the names it ssid i needed to use. so i just deleted the email and will not pursue it any more. the email was from netgear security depatment but if it was that important they should have made it easier to follow. thanks
antinode
Jan 19, 2018Guru
Revealing the model of your "my router" might help others decide,
too.
> [...] if it was that important they should have made it easier to
> follow.
It's easy to follow, if you don't have a cable modem(+router).
Apparently, Netgear broadcasts these notices to every victim e-mail
address in their records, irregardful of what equipment any particular
victim might have, whether there actually is a firmware update for any
particular model, or, in the cable modem(+router) case, whether the
victim has any ability to install it. And then, the message itself
doesn't say any of that, so the victims tend to believe what it says.
- corvairbobJan 19, 2018Tutor
the model is c3700 and like one other said the email must have been a genaric email. because when i followed those instructions i did not have some of the items on my router they said to use. so like i said i just deleted the email and i'm forgetting the update as i do not think it was for my router anyway. thanks
