fodderdad
Sep 07, 2019Aspirant
firmware upgrade corrupt files wndr4300v2 V1 files ok but not usable.
The firmware updates , both the released and beta, are corrupt. Nowhere I could find to report to netgear without paying for customer support. no contact information like phone numbers or chat.
- Sep 10, 2019
> [...] when I attempt to use the file a message appears indicating the
> file to be corrupt. [...]"use" _how_? What was the actual message? Copy+paste is your
friend. See "Note that attempting to "open" [...]", above.> [...] I assumed [...]
Seldom a wise course.
> [...] Read the "Release Notes" file for instructions.
Did you?
antinode
Sep 07, 2019Guru
> The firmware updates , both the released and beta, are corrupt. [...]
_Which_ "The firmware updates"? Obtained where? How, exactly, did
you detect this corruption?
None of this is a useful problem description. It does not say what
you did. It does not say what happened when you did it. As usual,
showing actual actions (commands) with their actual results (error
messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.
Visit http://netgear.com/support , put in your model number, and look
for Downloads. (For older versions, under Firmware and Software
Downloads, look for "View Previous Versions".) Find the kit(s).
Download the kit(s) you want. Read the "Release Notes" file for
instructions.
Note that attempting to "open" a firmware image file using your
computer operating system (instead of following the instructions in the
Release Notes file or User Manual for your device) can be expected to
fail with a misleading error message.
And there's an approprate forum for your not-a-"Cable Modems &
Routers" device:
https://community.netgear.com/t5/x/bd-p/home-wifi-routers-general
