fodderdad
Sep 07, 2019Aspirant
firmware upgrade corrupt files wndr4300v2 V1 files ok but not usable.
The firmware updates , both the released and beta, are corrupt. Nowhere I could find to report to netgear without paying for customer support. no contact information like phone numbers or chat.
- Sep 10, 2019
> [...] when I attempt to use the file a message appears indicating the
> file to be corrupt. [...]"use" _how_? What was the actual message? Copy+paste is your
friend. See "Note that attempting to "open" [...]", above.> [...] I assumed [...]
Seldom a wise course.
> [...] Read the "Release Notes" file for instructions.
Did you?
fodderdad
Sep 10, 2019Aspirant
The firmware update was the latest one on the netgear support website for my router model 1.0.0.60 and is 2 numbers higher than the current firmware on my router 1.0.0.56. The netgear support website is the origin of the update and when I attempt to use the file a message appears indicating the file to be corrupt. I am sorry but I assumed that the statements made on a netgear site would infere the site was used as an origin and that the latest released firmware revision would be selected. 1.0.0.60 (beta) was not chosen since it is beta. I am using windows 10 x64. using the firmware update on the router indicates no updates are available.
antinode
Sep 10, 2019Guru
Did you?
- fodderdadSep 11, 2019Aspirant
As my statements indicate I am a novice at best.
I once again tried to upgrade per the notes, to no avail. I opened the .zip file and copied the .img file to the desktop that allowed the upgrade through the router interface.I could not extract the .img file; only copy from the .zip file. I still get devices connecting in the network map without notifing me of a connect attempt ( randomly a phone, TV, and blueray player) Can I block by MAC address because no IP is identified.
- antinodeSep 11, 2019Guru
> I once again tried to upgrade per the notes, to no avail. [...]
Does that mean that the update failed, or that the update worked, but
it didn't solve your primary problem?> [...] I could not extract the .img file; only copy from the .zip
> file. [...]Right-click > Extract All, but copying should work, too.
> [...] Can I block by MAC address because no IP is identified.
If these devices have no IP addresses, then they may already be
blocked (somehow).Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual. Read. Look for "Control
Access to the Internet"?
