brycewade
Jan 13, 2020Follower
Firmware upgrade for Cable Haunt vulnerability on CM1000?
With the recent announcment of the Cable Haunt vulnerability (see https://cablehaunt.com/) and the inclusion of the CM1000 modem on the list of affected devices, is there an updated firmware availabl...
linuxnutt
Jan 18, 2020Aspirant
Just a quick question in connecting to CM500 "spectrum" web screen/page at http://192.168.100.1:8080 typically is there a default password to connect as I've changed my admin password from the unsecure user "admin" and "password" credentilas to a more secure one. Yet when I try to use the default password or my changed admin password to connect http://192.168.100.1:8080 I'm not able to connect.
In addition I'll add here for Linux firewall users how to block access to your cablemodem using null routes to blackhole the 192.168.100.1 IP. I spend a long minute trying to find this solution ( :-) ) and its really very easy you don't need to add an iptable rule to your firewall.
My network setup: Internet--ISP--Cable Modem--Smoothwall Firewall--Internal Network. On the firewall add a null route to blackhole the cable modem ip address (192.168.100.1). Here is a reference for specific how to setup and remove details - nixcraft, "How Do I Drop or Black Attackers IP Address with Null Routes on a Linux", https://www.cyberciti.biz/tips/how-do-i-drop-or-block-attackers-ip-with-null-routes.html. I've done it and the cable modem access from the internal network is blocked. This should help until Broadcom, Modem manafactures and your ISP come up with a firmware fix for Cable Haunt. If you need to reconnect to the cable modem for some reason simple remove the null route block.
Jan 18, 2020Guru - Experienced User
I've changed the PW on my CM1100 and I can still access the analyzer page using the PW I set for the modems main web page.
linuxnutt wrote:Just a quick question in connecting to CM500 "spectrum" web screen/page at http://192.168.100.1:8080 typically is there a default password to connect as I've changed my admin password from the unsecure user "admin" and "password" credentilas to a more secure one. Yet when I try to use the default password or my changed admin password to connect http://192.168.100.1:8080 I'm not able to connect.
