prism37s
Aug 14, 2016Follower
Firmware upgrade
I have a CG3000Dv1 wireless Cable Gateway, which on the Netgear site, shows as a CG3000-1STAUS with a firmware download of v1.1 and on the genie it says my firmware is v5.5.7, (which is after I rest...
- Aug 17, 2016
Hello prism37s
All the firmware for cable modems are pushed out by the isp once you make a connection with the ISP and reset the modem it should update to the latest firmware on its own.
DarrenM
DarrenM
Aug 17, 2016Sr. NETGEAR Moderator
Hello prism37s
DarrenM
