robotman
Jan 05, 2020Aspirant
Fixed IP for connected device?
I have a number of devices that get DHCP addresses from my cable modem. I'd like to assign one of these devices a fixed address or at least "lock" the address to the device it so the address doesn't ...
robotman
Jan 08, 2020Aspirant
Thanks for the response. I understand the difference, and that makes sense, but lets say I'm *only* using the Negear CMV... with my cable provider and plug in my laptop directly to the modem. I still get issued an IP address, get DNS etc. As indicated in this diagram:
https://www.netgear.com/home/products/networking/cable-modems-routers/CM1150V.aspx
I would have thought there was some settings for that? For example if I wanted to use an alternate DNS provider?
antinode
Jan 08, 2020Guru
> [...] plug in my laptop directly to the modem. [...]
> I would have thought there was some settings for that? [...]
Not really. You should be able to get to the settings on any DOCSIS
modem at "192.168.100.1", but I doubt that you'd find what you seek
there. Without a router, your computer negotiates directly with your
ISP. (With a router, the router negotiates directly with your ISP.)
> [...] I still get issued an IP address, get DNS etc.
From your ISP.
> [...] For example if I wanted to use an alternate DNS provider?
Tell your (unspecified) "my laptop"; the modem isn't interested (or
involved, except as a conduit).
