tpaplham
Aug 10, 2021Follower
Floppy antennae on C6200
I just purchased a C6200 cable modem router, and straight away I noticed that after attaching the antennae as tightly as possible, they still remain fairly loose and floppy, especially the right one,...
olympos1625
Sep 03, 2021NETGEAR Employee Retired
Hi tpaplham
Good day!
Welcome to NETGEAR Community!
First of all, we are sorry for not being able to get back to you immediately due to the backlogs. Are you still having the issue? If the antenna is the problem, hardware replacement should fix this. Did you try returning the device to the store and have it replace from there since this is new?
Please do not hesitate to let me know if you need further assistance.
Oliver
Community Team
