mekes123's avatar
mekes123
Follower
Apr 06, 2019
Forgot login for www.routerlogin.net and answers from password reset questions
I resenly forgot my  www.routerlogin.net  loggin information , when they asked me security questions to reset my password I forgot those too. Any way to reset a new user and password knowing that a whie back , It looked like i changed it from the defult which i regret. Tried to call but it seems I dont have the.... prevviliage or however this system wors at this time
1 Reply
  • plemans's avatar
    If you don't know your login info or security questions, you would need to do a full reset of the device to clear out the info.
    Hold the reset for 7-10 seconds and let it reboot afterward. you'll have to fully set the device back up. The device you're talking about is the C6300 that you put for model I take it? If so here's the support site info.
    https://www.netgear.com/support/product/C6300.aspx
