fmd159
Jun 30, 2019Follower
Foxtel V6510-1FXAUS - how do manage?? NetGear Genie not working and Nighthawk not supporting
I have a Foxtel V6510-1FXAUS - running latest firmware I want to restrict internet access for my son. I have downloaded both genie and nighthawk apps. nighthawk does not support this device, genie won...
Jun 30, 2019Guru - Experienced User
Genie and NightHawk apps are only for Netgear products. Genie is slowly being phased out I believe for most NG routers.
You'll need to contact Foxtel for help and information on there product.
Good Luck.
fmd159 wrote:
I have a Foxtel V6510-1FXAUS - running latest firmware I want to restrict internet access for my son. I have downloaded both genie and nighthawk apps. nighthawk does not support this device, genie wont connect with router admin account?? any ideas?
- antinodeJun 30, 2019Guru
> Genie and NightHawk apps are only for Netgear products. [...]
The V6510 may be a "Netgear product", but it's an ISP-specific
product with ISP-specific firmware, so support for it in any app is
determined by the ISP and the app vendor.
> My Setup [...]Helpful as ever.
