Redph
May 17, 2020Aspirant
Frequent Disconnections
Ever since I changed my networks Port Forwarding in order to change my NAT Type on my Ps4 from 3 to 2, I have been getting at least one two random disconnections daily and the error I get on Chrome r...
Redph
May 23, 2020Aspirant
Disconnections are on the PC, which is wired.
I am using auto channels for the wireless, I can switch it to manual but I'm not sure if that will resolve the issue.
The ISP had installed a new coax cable with splitters 6 months ago. Again I doubt that's the issue.
This was never an issue until I added a bunch of port forwarding on the "Port Forwarding/Port Triggering and made adjustments to my to the Gateway DHCP server IP.
If anything, is there a way to do a factory reset on the settings that I had changed? I think I'd just like to go back to the way it was.
Thanks for the comment!
May 23, 2020Guru - Experienced User
Yes, press the reset button in back for 15 seconds then release. Setup from scratch.
