JPJessen
Jul 21, 2016Aspirant
Frequent disconnects 3700 firmware version V2.02.08
I started using ROKU two weeks ago. Since starting that, I have frequent dropped signals from comcast. If I reboot the modem then it will usually connect to the internet after a few minutes. This hap...
DarrenM
Jul 25, 2016Sr. NETGEAR Moderator
Hello Jpjessen
I notice you have a Ip address pinging you alot do you know what that Ip address is that is causing the DOS attacks? And have you tried to disconnect the ROKU from the modem for a time to see if the issues clear up and we can narrow it down.
DarrenM
- JPJessenJul 30, 2016Aspirant
I installed the hot fix the other day and basically had no problems for about a week. Last evening it started going down again. I have no idea what is up with the DOS attacks or the ping of death. I really have no idea what a DOS attack is. I just know that when I disconnected my cable tv and started streaming over the internet that it has become more frequent. Here are the latest logs. Any help would be appreciated
Apply Cancel
Description Count Last Occurrence Target Source
[admin login] from source 0.0.0.0 1 Sat Jul 30 06:15:55 2016 0.0.0.0:0 0.0.0.0:0
[ login failure] from source 0.0.0.0 1 Sat Jul 30 06:15:49 2016 0.0.0.0:0 0.0.0.0:0
[DHCP IP: 192.168.0.11] to MAC address 00:25:4b:99:03:c7 1 Sat Jul 30 06:15:34 2016 0.0.0.0:0 0.0.0.0:0
[DoS attack: Illegal Fragments] from 130.0.165.96, port 0 1 Sat Jul 30 05:08:27 2016 89.168.12.203:0 130.0.165.96:0
[DoS attack: Ping Of Death] from 130.0.165.96, port 0 5 Sat Jul 30 05:08:27 2016 89.168.12.203:0 130.0.165.96:0
[DoS attack: Teardrop or derivative] from 130.0.165.96, port 0 1 Sat Jul 30 05:07:15 2016 89.168.12.203:0 130.0.165.96:0
[Internet connected] IP address: 73.133.141.74 1 Sat Jul 30 04:17:09 2016 0.0.0.0:0 0.0.0.0:0
[Time synchronized with ToD server] 1 Sat Jul 30 04:16:56 2016 0.0.0.0:0 0.0.0.0:0
[Internet disconnected] 1 Sat Jul 30 04:16:30 2016 0.0.0.0:0 0.0.0.0:0
[DHCP IP: 192.168.0.11] to MAC address 00:25:4b:99:03:c7 1 Sat Jul 30 02:07:04 2016 0.0.0.0:0 0.0.0.0:0
[Internet connected] IP address: 73.133.141.74 1 Sat Jul 30 01:14:05 2016 0.0.0.0:0 0.0.0.0:0
[Time synchronized with ToD server] 1 Sat Jul 30 01:12:56 2016 0.0.0.0:0 0.0.0.0:0
[Internet disconnected] 1 Sat Jul 30 01:12:26 2016 0.0.0.0:0 0.0.0.0:0
[Internet connected] IP address: 73.133.141.74 1 Sat Jul 30 01:01:50 2016 0.0.0.0:0 0.0.0.0:0
[Time synchronized with ToD server] 1 Sat Jul 30 01:00:41 2016 0.0.0.0:0 0.0.0.0:0
[Internet disconnected] 1 Sat Jul 30 01:00:11 2016 0.0.0.0:0 0.0.0.0:0
[Internet connected] IP address: 73.133.141.74 1 Sat Jul 30 00:18:47 2016 0.0.0.0:0 0.0.0.0:0
[Time synchronized with ToD server] 1 Sat Jul 30 00:17:38 2016 0.0.0.0:0 0.0.0.0:0
[Internet disconnected] 1 Sat Jul 30 00:17:14 2016 0.0.0.0:0 0.0.0.0:0
[Internet connected] IP address: 73.133.141.74 1 Fri Jul 29 22:21:26 2016 0.0.0.0:0 0.0.0.0:0
[Time synchronized with ToD server] 1 Fri Jul 29 22:21:13 2016 0.0.0.0:0 0.0.0.0:0
[Internet disconnected] 1 Fri Jul 29 22:20:44 2016 0.0.0.0:0 0.0.0.0:0
[Internet connected] IP address: 73.133.141.74 1 Fri Jul 29 22:10:26 2016 0.0.0.0:0 0.0.0.0:0
[Time synchronized with ToD server] 5 Fri Jul 29 22:09:16 2016 0.0.0.0:0 0.0.0.0:0
[Internet disconnected] 1 Fri Jul 29 22:06:27 2016 0.0.0.0:0 0.0.0.0:0
[DHCP IP: 192.168.0.14] to MAC address 4c:7c:5f:93:cb:4b 1 Fri Jul 29 21:07:48 2016 0.0.0.0:0 0.0.0.0:0
[DHCP IP: 192.168.0.14] to MAC address 4c:7c:5f:93:cb:4b 1 Fri Jul 29 21:07:47 2016 0.0.0.0:0 0.0.0.0:0
[Internet connected] IP address: 73.133.141.74 1 Fri Jul 29 21:02:34 2016 0.0.0.0:0 0.0.0.0:0
[Time synchronized with ToD server] 1 Fri Jul 29 21:02:21 2016 0.0.0.0:0 0.0.0.0:0
[Internet disconnected] 1 Fri Jul 29 21:01:50 2016 0.0.0.0:0 0.0.0.0:0
[Internet connected] IP address: 73.133.141.74 1 Fri Jul 29 20:47:09 2016 0.0.0.0:0 0.0.0.0:0
[Time synchronized with ToD server] 1 Fri Jul 29 20:46:56 2016 0.0.0.0:0 0.0.0.0:0
[Internet disconnected] 1 Fri Jul 29 20:46:27 2016 0.0.0.0:0 0.0.0.0:0
[Internet connected] IP address: 73.133.141.74 1 Fri Jul 29 20:33:12 2016 0.0.0.0:0 0.0.0.0:0
[Time synchronized with ToD server] 1 Fri Jul 29 20:32:59 2016 0.0.0.0:0 0.0.0.0:0
[Internet disconnected] 1 Fri Jul 29 20:32:28 2016 0.0.0.0:0 0.0.0.0:0
[DHCP IP: 192.168.0.13] to MAC address 20:c9:d0:d7:63:47 1 Fri Jul 29 20:32:28 2016 0.0.0.0:0 0.0.0.0:0
[Internet connected] IP address: 73.133.141.74 1 Fri Jul 29 20:24:39 2016 0.0.0.0:0 0.0.0.0:0
[Time synchronized with ToD server] 1 Fri Jul 29 20:23:30 2016 0.0.0.0:0 0.0.0.0:0
[Internet disconnected] 1 Fri Jul 29 20:23:06 2016 0.0.0.0:0 0.0.0.0:0
[DHCP IP: 192.168.0.11] to MAC address 00:25:4b:99:03:c7 1 Fri Jul 29 19:43:49 2016 0.0.0.0:0 0.0.0.0:0
[DHCP IP: 192.168.0.22] to MAC address b8:a1:75:47:f9:23 1 Fri Jul 29 19:00:46 2016 0.0.0.0:0 0.0.0.0:0
[Internet connected] IP address: 73.133.141.74 1 Fri Jul 29 19:00:22 2016 0.0.0.0:0 0.0.0.0:0
[Time synchronized with ToD server] 1 Fri Jul 29 19:00:09 2016 0.0.0.0:0 0.0.0.0:0
[Internet disconnected] 1 Fri Jul 29 18:59:39 2016 0.0.0.0:0 0.0.0.0:0
[DoS attack: Ping Of Death] from 130.0.165.96, port 0 1 Fri Jul 29 18:58:33 2016 4.216.106.61:0 130.0.165.96:0
[DHCP IP: 192.168.0.22] to MAC address b8:a1:75:47:f9:23 1 Fri Jul 29 18:56:42 2016 0.0.0.0:0 0.0.0.0:0
[DHCP IP: 192.168.0.22] to MAC address b8:a1:75:47:f9:23 1 Fri Jul 29 18:42:41 2016 0.0.0.0:0 0.0.0.0:0
[Internet connected] IP address: 73.133.141.74 1 Fri Jul 29 18:42:00 2016 0.0.0.0:0 0.0.0.0:0
[Time synchronized with ToD server] 1 Fri Jul 29 18:40:50 2016 0.0.0.0:0 0.0.0.0:0
[Internet disconnected] 1 Fri Jul 29 18:40:18 2016 0.0.0.0:0 0.0.0.0:0
[DHCP IP: 192.168.0.22] to MAC address b8:a1:75:47:f9:23 1 Fri Jul 29 18:37:06 2016 0.0.0.0:0 0.0.0.0:0
[DHCP IP: 192.168.0.22] to MAC address b8:a1:75:47:f9:23 1 Fri Jul 29 18:35:16 2016 0.0.0.0:0 0.0.0.0:0
[DHCP IP: 192.168.0.13] to MAC address 20:c9:d0:d7:63:47 1 Fri Jul 29 18:34:22 2016 0.0.0.0:0 0.0.0.0:0
[DHCP IP: 192.168.0.14] to MAC address 4c:7c:5f:93:cb:4b 1 Fri Jul 29 18:34:19 2016 0.0.0.0:0 0.0.0.0:0
[DHCP IP: 192.168.0.12] to MAC address c0:1a:da:a6:3d:25 1 Fri Jul 29 18:34:14 2016 0.0.0.0:0 0.0.0.0:0
[Internet connected] IP address: 73.133.141.74 1 Fri Jul 29 18:34:07 2016 0.0.0.0:0 0.0.0.0:0
[DHCP IP: 192.168.0.12] to MAC address c0:1a:da:a6:3d:25 1 Fri Jul 29 18:34:03 2016 0.0.0.0:0 0.0.0.0:0
[DHCP IP: 192.168.0.22] to MAC address b8:a1:75:47:f9:23 1 Fri Jul 29 18:33:58 2016 0.0.0.0:0 0.0.0.0:0
[DHCP IP: 192.168.0.12] to MAC address c0:1a:da:a6:3d:25 1 Fri Jul 29 18:33:52 2016 0.0.0.0:0 0.0.0.0:0
[DHCP IP: 192.168.0.22] to MAC address b8:a1:75:47:f9:23 1 Fri Jul 29 18:33:47 2016 0.0.0.0:0 0.0.0.0:0
[DHCP IP: 192.168.0.12] to MAC address c0:1a:da:a6:3d:25 1 Fri Jul 29 18:33:41 2016 0.0.0.0:0 0.0.0.0:0
[DHCP IP: 192.168.0.22] to MAC address b8:a1:75:47:f9:23 1 Fri Jul 29 18:33:36 2016 0.0.0.0:0 0.0.0.0:0
[DHCP IP: 192.168.0.12] to MAC address c0:1a:da:a6:3d:25 1 Fri Jul 29 18:33:30 2016 0.0.0.0:0 0.0.0.0:0
[DHCP IP: 192.168.0.22] to MAC address b8:a1:75:47:f9:23 1 Fri Jul 29 18:33:25 2016 0.0.0.0:0 0.0.0.0:0
[DHCP IP: 192.168.0.12] to MAC address c0:1a:da:a6:3d:25 1 Fri Jul 29 18:33:19 2016 0.0.0.0:0 0.0.0.0:0
[DHCP IP: 192.168.0.22] to MAC address b8:a1:75:47:f9:23 1 Fri Jul 29 18:33:14 2016 0.0.0.0:0 0.0.0.0:0
[DHCP IP: 192.168.0.13] to MAC address 20:c9:d0:d7:63:47 1 Fri Jul 29 18:33:13 2016 0.0.0.0:0 0.0.0.0:0
[DHCP IP: 192.168.0.12] to MAC address c0:1a:da:a6:3d:25 1 Fri Jul 29 18:33:08 2016 0.0.0.0:0 0.0.0.0:0
[DHCP IP: 192.168.0.22] to MAC address b8:a1:75:47:f9:23 1 Fri Jul 29 18:33:03 2016 0.0.0.0:0 0.0.0.0:0
[DHCP IP: 192.168.0.13] to MAC address 20:c9:d0:d7:63:47 1 Fri Jul 29 18:33:01 2016 0.0.0.0:0 0.0.0.0:0
[Time synchronized with ToD server] 1 Fri Jul 29 18:32:57 2016 0.0.0.0:0 0.0.0.0:0
[DHCP IP: 192.168.0.12] to MAC address c0:1a:da:a6:3d:25 1 Fri Jul 29 18:32:56 2016 0.0.0.0:0 0.0.0.0:0
[DHCP IP: 192.168.0.22] to MAC address b8:a1:75:47:f9:23 1 Fri Jul 29 18:32:51 2016 0.0.0.0:0 0.0.0.0:0
[DHCP IP: 192.168.0.13] to MAC address 20:c9:d0:d7:63:47 1 Fri Jul 29 18:32:49 2016 0.0.0.0:0 0.0.0.0:0
[DHCP IP: 192.168.0.12] to MAC address c0:1a:da:a6:3d:25 1 Fri Jul 29 18:32:45 2016 0.0.0.0:0 0.0.0.0:0
[DHCP IP: 192.168.0.22] to MAC address b8:a1:75:47:f9:23 1 Fri Jul 29 18:32:40 2016 0.0.0.0:0 0.0.0.0:0
[DHCP IP: 192.168.0.13] to MAC address 20:c9:d0:d7:63:47 1 Fri Jul 29 18:32:38 2016 0.0.0.0:0 0.0.0.0:0
[DHCP IP: 192.168.0.12] to MAC address c0:1a:da:a6:3d:25 1 Fri Jul 29 18:32:33 2016 0.0.0.0:0 0.0.0.0:0
[DHCP IP: 192.168.0.22] to MAC address b8:a1:75:47:f9:23 1 Fri Jul 29 18:32:29 2016 0.0.0.0:0 0.0.0.0:0
[DHCP IP: 192.168.0.13] to MAC address 20:c9:d0:d7:63:47 1 Fri Jul 29 18:32:27 2016 0.0.0.0:0 0.0.0.0:0
[Time synchronized with ToD server] 1 Fri Jul 29 18:32:27 2016 0.0.0.0:0 0.0.0.0:0
[DHCP IP: 192.168.0.12] to MAC address c0:1a:da:a6:3d:25 1 Fri Jul 29 18:32:23 2016 0.0.0.0:0 0.0.0.0:0
[DHCP IP: 192.168.0.22] to MAC address b8:a1:75:47:f9:23 1 Fri Jul 29 18:32:19 2016 0.0.0.0:0 0.0.0.0:0
[DHCP IP: 192.168.0.13] to MAC address 20:c9:d0:d7:63:47 1 Fri Jul 29 18:32:17 2016 0.0.0.0:0 0.0.0.0:0
[DHCP IP: 192.168.0.12] to MAC address c0:1a:da:a6:3d:25 1 Fri Jul 29 18:32:12 2016 0.0.0.0:0 0.0.0.0:0
[DHCP IP: 192.168.0.22] to MAC address b8:a1:75:47:f9:23 1 Fri Jul 29 18:32:07 2016 0.0.0.0:0 0.0.0.0:0
[DHCP IP: 192.168.0.13] to MAC address 20:c9:d0:d7:63:47 1 Fri Jul 29 18:32:06 2016 0.0.0.0:0 0.0.0.0:0
[DHCP IP: 192.168.0.12] to MAC address c0:1a:da:a6:3d:25 1 Fri Jul 29 18:32:01 2016 0.0.0.0:0 0.0.0.0:0
[DHCP IP: 192.168.0.22] to MAC address b8:a1:75:47:f9:23 1 Fri Jul 29 18:31:56 2016 0.0.0.0:0 0.0.0.0:0
[DHCP IP: 192.168.0.12] to MAC address c0:1a:da:a6:3d:25 1 Fri Jul 29 18:31:50 2016 0.0.0.0:0 0.0.0.0:0
[DHCP IP: 192.168.0.22] to MAC address b8:a1:75:47:f9:23 1 Fri Jul 29 18:31:44 2016 0.0.0.0:0 0.0.0.0:0
[DHCP IP: 192.168.0.12] to MAC address c0:1a:da:a6:3d:25 1 Fri Jul 29 18:31:39 2016 0.0.0.0:0 0.0.0.0:0
[DHCP IP: 192.168.0.22] to MAC address b8:a1:75:47:f9:23 1 Fri Jul 29 18:31:33 2016 0.0.0.0:0 0.0.0.0:0
[DHCP IP: 192.168.0.12] to MAC address c0:1a:da:a6:3d:25 1 Fri Jul 29 18:31:28 2016 0.0.0.0:0 0.0.0.0:0
[DHCP IP: 192.168.0.22] to MAC address b8:a1:75:47:f9:23 1 Fri Jul 29 18:31:22 2016 0.0.0.0:0 0.0.0.0:0
[DHCP IP: 192.168.0.14] to MAC address 4c:7c:5f:93:cb:4b 1 Fri Jul 29 18:31:18 2016 0.0.0.0:0 0.0.0.0:0
[DHCP IP: 192.168.0.22] to MAC address b8:a1:75:47:f9:23 1 Fri Jul 29 18:31:11 2016 0.0.0.0:0 0.0.0.0:0
[DHCP IP: 192.168.0.22] to MAC address b8:a1:75:47:f9:23 1 Fri Jul 29 18:31:00 2016 0.0.0.0:0 0.0.0.0:0
[Time synchronized with ToD server]- DarrenMAug 03, 2016Sr. NETGEAR Moderator
Hello JPjessen
Dos attack is when someone is trying to make you connection unusable by flooding your network with packets or it could just be a some program or website trying to do something but ends up looking like a Dos attack.
https://en.wikipedia.org/wiki/Denial-of-service_attack
DarrenM
- jbwmsAug 12, 2016Aspirant
The entries that look like this:
correlate with DHCP failures. I ran wireshark and found a normal DHCP transaction until a NAK from the router in response to my device's request message. This happened to other devices as their leases renewed. Rebooting the router resolved the condition.
Pretty sure this is a defect that will require a software change.
