shady127
Apr 03, 2015Novice
Frequent disconnects
Hello I have a C6300(AC1750) modem router and I've been experiencing frequent disconnects. They last for about a minute. Its very noticeable when streaming Netflix, a Skype video call or online gamin...
shady127
Apr 04, 2015Novice
I'm thinking it might be this bridged connection causing it?
- ourflatAug 11, 2015Aspirant
I bought mine yesterday and have the same problem. I'm using TWC as my ISP. Haven't figured it out yet!
Frank
- DarrenMAug 13, 2015Sr. NETGEAR Moderator
Hello ourflat
The first thing I would do is check all my connections make sure the cable is tight on the modem the next thing is to check if you have a cable splitter on the line going to the modem if you do try taking that off and go directly to the wall and see if you are experiencing the issue. I would also contact TWC and have them check the levels of the modem and make sure they have the modem provisioned correctly. Last thing I would try is a factory reset on the modem and resetup all of your router settings. Hope to hear your feedback.
DarrenM
- ourflatAug 13, 2015Aspirant
Hi, couldn't wait any longer and grew tired of long phone calls to India for tech support. Returned item to store and recieved a replacement. The new AC-1750 works like a champ so I suspect the old unit was defective!
Frank
