PraveenV
Dec 03, 2016Follower
Frequent network drop in Nighthawk AC1900
I purchased the "NETGEAR Nighthawk AC1900 (24x8) Wi-Fi Cable Modem Router (C7000) DOCSIS 3.0 Certified for Xfinity Comcast" from Amazon. I see frequent short-disconnects on my Xfinity connection. Som...
DarrenM
Dec 09, 2016Sr. NETGEAR Moderator
Hello PraveenV
Do you have any kind of splitter on the cable line between the modem and the wall if so try removing it and connect direct to the wall outlet. You could post your modem logs here as well when the drops are happening may give some more detail.
DarrenM
