htownsam
Dec 03, 2018Aspirant
FS116 Switch dropping packets
I have been having issues where my unmanaged switch seems to be dropping packets. Many times when I try to access websites on my computers i will get the error "err empty response". If i flush dns it...
- Dec 03, 2018
> [...] the Comcast router. [...] The cable modem [...]
Still wondering if those are one gizmo or two.
> [...] The cable modem is the standard modem issued by comcast
> business. [...]
An actual maker and model number for these devices would be more
informative than "the standard".
> [...] what is the diferrence between the model that I have and a
> gigabit switch [...]
Gigabit (1000MHz) is faster than "Fast" (100MHz). With 75Mb/s
service from your ISP, you might not notice any difference in
communication with the outside world, but, if the various devices on
your LAN talk to each other, and if their interfaces and cables support
gigabit operation, then intra-LAN communication could be faster with a
faster switch.
> [...] and also can you recommend a model?
Not really. Netgear seems to have a GS116v2 which might be similar
(except faster), but I haven't done any serious shopping for such things
recently, so I know nothing. (I'd avoid any old junk which has a fan.)
https://www.netgear.com/images/datasheet/switches/GS105v5_GS108v4_GS116v2.pdf
htownsam
5 computers, a tv and a few other devices all connected directly to the switch via network cable which is connected directly to the Comcast router. I pay for 75mb down with comcast business and it works fine. The cable modem is the standard modem issued by comcast business.
"Unless your other equipment is old, and "Fast" Ethernet is not a
bottleneck, a gigabit switch might be a reasonable investment."
Sorry for the stupid question but what is the diferrence between the model that I have and a gigabit switch and also can you recommend a model?
Thanks,
Sam
antinode
Dec 03, 2018Guru
> business. [...]
faster switch.
