Southpaw07
Aug 14, 2020Aspirant
Genie app not connecting to router’s WiFi
My iPhone and other devices are connected to my WiFi network Via my NETGEAR nighthawk C7000 router, but when I open the Genie app it says to connect my mobile device to my NETGEAR’s router WiFi as i...
Aug 15, 2020Guru - Experienced User
Please post about this over in the Genie app forum:
https://community.netgear.com/t5/Genie/bd-p/home-genie
Good Luck.
- Southpaw07Aug 15, 2020AspirantCorrect me if I’m wrong but I think I posted it in both the genie app forum and also the modem/ router forum. I originally posted it I think on the genie app forum but then someone messaged me saying I should consider posting it under modem/router forum.
- FURRYe38Aug 16, 2020Guru - Experienced User
IF your devices are connecting to the modem fine and also you can access the modems web page using a PC or laptop and web browser fine, then this is a genie app issue.
- Elliespop2Aug 16, 2020AspirantI cannot login to netgear genie. I can put my password in but my administrator ID will not let me type anything. The cursor will not go there. I have no issues with my router, I just want to update the firmware/software and I cannot
