uptownvideo
Oct 11, 2017Apprentice
Genie app not working
My cable modem router has always had problems using the Genie App. Since the major upgrade to the app I have nto been able to login at all. Will Netgear please fix this? This is with my iphone 6 r...
uptownvideo
The ios app version is 3.1.36
The firmware version on the router is 2.01.14
Cox is my isp.
Cox is my isp.
vkdelta
Oct 11, 2017NETGEAR Employee Retired
please post a screenshot of the app error.
- uptownvideoOct 12, 2017ApprenticeThis is what happens when I try to log in locally. I know the password is correct.
- vkdeltaOct 12, 2017NETGEAR Employee Retired
are you sure it is connected to C6300 WIFI?
- uptownvideoOct 12, 2017ApprenticeYes, my iphone and tablet are on the same network. The old app worked but I can nor longer download it. I see others in this community have this problem also.
