uptownvideo
Oct 11, 2017Apprentice
Genie app not working
My cable modem router has always had problems using the Genie App. Since the major upgrade to the app I have nto been able to login at all. Will Netgear please fix this? This is with my iphone 6 r...
uptownvideo
Oct 12, 2017Apprentice
This is what happens when I try to log in locally. I know the password is correct.
vkdelta
Oct 13, 2017NETGEAR Employee Retired
are you sure it is connected to C6300 WIFI?
- uptownvideoOct 13, 2017ApprenticeYes, my iphone and tablet are on the same network. The old app worked but I can nor longer download it. I see others in this community have this problem also.
- vkdeltaOct 13, 2017NETGEAR Employee Retired
Can you please check the app version again? sorry to ask few times.
Please take the screenshot of the app version to make suree it is 3.1.36.
- uptownvideoOct 19, 2017ApprenticeThis is screenshot of the app. Please help and get this fixed. Others on this board have had this issue also.
