uptownvideo
Oct 11, 2017Apprentice
Genie app not working
My cable modem router has always had problems using the Genie App. Since the major upgrade to the app I have nto been able to login at all. Will Netgear please fix this? This is with my iphone 6 r...
uptownvideo
Oct 13, 2017Apprentice
Yes, my iphone and tablet are on the same network. The old app worked but I can nor longer download it. I see others in this community have this problem also.
vkdelta
Oct 13, 2017NETGEAR Employee Retired
Can you please check the app version again? sorry to ask few times.
Please take the screenshot of the app version to make suree it is 3.1.36.
- uptownvideoOct 19, 2017ApprenticeThis is screenshot of the app. Please help and get this fixed. Others on this board have had this issue also.
- uptownvideoJan 04, 2018Apprentice
Hello Netgear! Do you have any plans on fixing the Genie App? I have been loyal for more than 10 years and I will change if you do not start listening to your customers.
