KNDYGRM
Oct 14, 2017Follower
Genie reset issues
I got his Router amost a year and ahalf ago, but because of upgrading my internet it no longer works with my provider. So i wanted to wipe it clean and send it to my inlaws who need a new one. the problem is i can't log in to the browser router log in page to reset all that info. http://www.routerlogin.net or http://www.routerlogin.com. even though i have it hooked in through my new router/modem and are able to use the internet perfectly fine. I don;t want ot give my inlaws my info and passwords that i had set up. Is there a way to reset it without having to use the brower? i can use the genie app on both my phone and my Mac just fine.
1 Reply
- DarrenMSr. NETGEAR Moderator
Yes you just need to hold the reset button on the back of the modem while its plugged in for 10+ seconds this will factory reset the unit.
DarrenM
