Mikeberry3232
Aug 14, 2018Aspirant
Get 1 gb speed from Netgear C700 AC1900
I have a Nighthawk C700 AC1900 which says that it supports up to 960 MBPS yet Comcast is telling me that it can't get anywhere near that. I called Netgear customer service and they stated that it mos...
michaelkenward
Aug 15, 2018Guru - Experienced User
First, I assume that you mean C7000.
Second, that is a cable modem.
By the way, you have posted your message in the section of this community given over to Nighthawk WiFi Routers. Your devices is a cable modem. You might get better replies, and find other answers, over in the appropriate section:
Cable Modems, Routers and DSL Modems - NETGEAR Communities
Then there is the 960 Mbps bit. Is that wired? Wifi? What do you get?
Mikeberry3232
Aug 15, 2018Aspirant
Yes C7000 is what I meant. I'm getting 245 mbps on wifi. I have not checked it hard wired yet.
