corvairbob
Oct 07, 2019Tutor
getting my cameras thru the r6300 router
i tried to post this saturday but i was told to move it to a link provided and i went to that link and got no replies so i will give it a go again. if it is wrong sorry. some histroy first. i ha...
corvairbob
Oct 07, 2019Tutor
i tired that with your link and it did not go. sorry but that link did not take me anywhere but to this page. maybe you can move but i could not find that r site.
Oct 07, 2019Guru - Experienced User
Can you access this forum?
https://community.netgear.com/t5/General-WiFi-Routers-Non/bd-p/home-wifi-routers-general
- corvairbobOct 07, 2019Tutor
ok i clicked that link and copied the post into that section thanks now to see if someone has a fix. thanks.
- FURRYe38Oct 07, 2019Guru - Experienced User
:smileywink:
- corvairbobOct 08, 2019Tutor
ok yesterday window helpers on a different issue had me do ho updates for getting a miracast to work. and believe it or not when hp did a bios update it did something to the r6300 and the c3700 setup and kicked me offline. i spent 3 hours getting back online and had to take the router out of the system. so i'm just going to get me a combo unit that works with my neck of the woods that comcast told me will work and be dont with trying to get this conglomeration to work. i did get good speed with the router hooked into the system but i could not see m cameras from away from home. i finally got the c3700 back up and running and today i could see my cameras form away from home. not as fast but after i get a new combo unit i should get the pseed back i'm done trying to get 2 seperat usnit to connect and then see my cameras thru them. thanks for the help anyway
