jmason77089
May 21, 2020Tutor
giga bit Modem router combe with voice
I am trying to replace my gigabit modem from Comcast-Xfinity with a modem+router+voice. I have looked at several that say gigabit, but they also say good for upto 400 mbps. I am a bit confused. Doe...
jmason77089
May 22, 2020Tutor
Thanks everybody. I think I found what I needed. The deal isn't so much the speed as it is access. The modem, router with voice supplied by Xfinity only as two ethernet connections. I need 4. The one I bought has 4 plus 2 phone ports and goes upto 2 gigabits. Added to that, I am tired of paying rent on a POS.
May 22, 2020Guru - Experienced User
What did you get?
Yes not having to pay rent on something that doesn't work well is good.
FYI, you can always add more ports by installing a Gb LAN switch.
- jmason77089May 22, 2020Tutor
I got one recommended by Comcast for my set-up. I got the Motorola MT771 24X8 DOCSIS 3.0 AC1900 Dual Band WiFi gigabit Router with Voice.
It was recommended by Comcast for my set up. I already have a Gigabit switch incase I need more than 4 ports, but I didn't want extra equipment sitting on my station unless I had to.
- plemansMay 22, 2020Guru - Experienced UserJust an fyi, that device will max out at 600mbps speed through comcast.
But I hope it works great for you!
I've tested a similar arris before and it worked great. - FURRYe38May 22, 2020Guru - Experienced User
Ya I would check with the ISP to see if this model modem will work fully on there 1Gb plan if thats something your looking to use. Most ISP required a D3.1 modem with 32x8 channels for 1Gb services.
jmason77089 wrote:I got one recommended by Comcast for my set-up. I got the Motorola MT771 24X8 DOCSIS 3.0 AC1900 Dual Band WiFi gigabit Router with Voice.
