Zaprey
Jan 02, 2020Aspirant
Gigabit speed being throttled down
So we have 1000mbps internet plan with Comcast Xfinity. Modem - Netgear Nighthawk CM1200 Cable Modem Router - Netgear Nighthawk XR700 Pro Gaming Router Both are up to date with Firmware Connect...
Jan 03, 2020Guru - Experienced User
If you're having the issue on multiple routers, then it tends to point at either the line coming in, the modem, or some way you're setting up the routers.
Comcast technicians aren't the best for phone support. they're main goal is to get you off the line.
Do you have a screen snip of all your modem connections info? This can help a lot. As well as the logs.
If you have any splitter, attenuators, amplifiers in line, I'd recommend removing them. Preferably, I'd also recommend moving the modem to right where the coax enters the home. If that isn't possible, inspect the line for any damage, kinks, cheap/poor connectors, loose connectors, etc. Even small things can cause issues when you're running gigabit.
You've put that its happening every 1-3 hours roughly. If you hardwire into your modem for that period, what speeds do you get?
Are you using any port aggregation features?
- doeichelMay 12, 2020Aspirant
Same issue. After reboot, 1000Mbps down and 40Mbps up. 3 hours later, like clockwork, drops to 20-30Mbps down and 20-30Mbps up. Signal strength is fine. I do have link aggregation enabled - which is why I got this modem/router combo. Did anybody get this resolved??
- FURRYe38May 13, 2020Guru - Experienced User
Yes, disable LAG.
The CM1200 is NOT a modem/router combo. Its only a rmodem.
doeichel wrote:Same issue. After reboot, 1000Mbps down and 40Mbps up. 3 hours later, like clockwork, drops to 20-30Mbps down and 20-30Mbps up. Signal strength is fine. I do have link aggregation enabled - which is why I got this modem/router combo. Did anybody get this resolved??
- doeichelMay 13, 2020Aspirant
The router behind my CM1200 is a netgear RAX120 which is specifically listed as supporting LAG with the CM1200.
