mchwalowski
Oct 04, 2017Follower
GO INTO NETGEAR POPS P AS NETGEAR 100NAS; I HAVE NETGEAR N600 WIFI CABLE MODEM ROUTER MODEL C3700
I HAVE A NETGEAR N600 WIFI CABLE MODEM ROUTER DOCIS 3.0 MODEL C3700 I'M TRYING TO SET IT UP AND CHANGE PASSWORD BUT IT KEEPS SHOWING THAT IT'S A NETGEAR NAS100. ISN'T THAT INCORRECT? HOW DO I GET RID...
antinode
Oct 04, 2017Guru
1. Please find (and use) your Shift key(s).
Are you using a Web browser to do this? Assuming so, on what is this
Web browser running, a Windows PC? How is it connected to the C3700?
Do you have a Netgear NAS device on your LAN? (What happens if you
disconnect it?)
> I'VE ALREADY DOWNLOAED THE GENIE APP. [...]
I've never used it.
> [...] HTTP://ROUTERLOGIN.NET [...]
Have you tried specifying the router's numeric IP address (default:
192.168.0.1), instead?
