johncaspersmith
Mar 09, 2016Aspirant
GoFlex Home NAS won't appear on LAN of CG3000
My GoFlex Home NAS connects okay and appears on the network of my old ADSL modem (Billion BiPAC 7800VDOX). But when I connect it to our new Optus supplied cable modem Netgear CG3000-2STAUS the releva...
- Mar 10, 2016
Seagate technical support correctly identified the issue. On my old network I had set the NAS to have a particular IP and not obtain an IP automatically. I guess this could be an issue for any network device being moved from one network to another. Here is a slightly abridged version of their instructions:
Connect the GoFlex Home unit back to the old ADSL modem. Please access the administration page (e.g. Preferences) of the GoFlex Home device by launching the web browser and type-in the IP address of the GoFlex Home; Sign-in with the required GoFlex Home username and password; Check the "network mode or LAN settings" (e.g Obtain an IP address automatically: Yes/No). If you have set it to "No", change it to "Yes" so that it will obtain a dynamic IP address from the router/modem and submit/save the settings. Reconnect the GoFlex Home unit to the new router and check if it will be listed in the router's DHCP client list.
You will see an IP address and a MAC address [ex. 192.168.1.23 and 00:10:75:XX:YY:ZZ]. Note: All Seagate Consumer NAS units MAC address will start with 00:10:75;
johncaspersmith
Mar 10, 2016Aspirant
