patchtogether's avatar
Sep 23, 2022
google fiber connected to C7000 AC1900, Readyshare dissapear
I just switched to google fiber and use ethernet cable connecting to nighthawk C7000 cable router. I can connect to internet without any problem. However the Readyshare disappeared. Anybody know what should I do? The reason I use nighthawk is because there is no usb output on google wifi and I want to connect external hard drive to my network. Thanks!
1 Reply
  • plemans's avatar
    The C7000 is a modem/router combo device. I"m sure you needed to do a few shenanigans to get it to connect to the google fibre setup at all. So I'm surprised its working at all. Not sure how the changes you made will impact readyshare.
