jaylbo
Sep 30, 2020Follower
google mesh
Daily need to contact Comcast to resend signal to improve signal strength. Comcast says I should contact Netgear @ CM600 reconfiguration 1st, but Netgear says there is firmware upgrade with internet ...
schumaku
Oct 01, 2020Guru - Experienced User
jaylbo wrote:Comcast says I should contact Netgear @ CM600 reconfiguration 1st, but Netgear says there is firmware upgrade with internet connection.
Permitting the Internet connection (for the cable modem) is workable for a while, the first thing to do is to accept the proposed firmware upgrade on the CM600.
