jaylbo
Sep 30, 2020Follower
google mesh
Daily need to contact Comcast to resend signal to improve signal strength. Comcast says I should contact Netgear @ CM600 reconfiguration 1st, but Netgear says there is firmware upgrade with internet ...
Oct 01, 2020Guru - Experienced User
I'd be posting in the cable modem section for cm600 issues.
https://community.netgear.com/t5/Cable-Modems-Routers/bd-p/home-cable-modems-routers
When/iff you post there, include a screen snip of the cable connections page and the logs.
Also, if you have any splitters, amplifiers, or attenuators in the coax line, I'd remove them. check the coax for kinks, damage, corrosion, bad/cheap connectors, or even loose connections.
