NeenerIII
Aug 03, 2021Aspirant
Google Nest Wifi Router will no longer communicate with CM1000v2 Modem
Everyone working from home, kids at, etc, upgraded my network to a Google Nest Mesh (one Nest router as the router, two Nest routers connected as access points). My Modem is a CM1000v2 and I have Co...
Aug 03, 2021Guru - Experienced User
Try powering OFF both CM modem and the wifi router for 1 minute then back ON.
Ensure the cable between the modem and router is of good quality. CAT6 is recommended.
If the router won't connect to the modem and your direct connected PC does, then this is a issue with the router, not the modem.
